Converting from xlsx to ods
  1. Alignment is not preserved after conversion. (x2t.exe “D:\input.xlsx” “D:\output.ods”)
  2. If I open the input.xlsx file in an editor and “save as…”, the alignment is also not preserved.
    unnamed
Hey @dimka124, :wave:
Thanks for the report!
Does this happen with every XLSX file or only with this specific one?
If possible, could you share the file (or a minimal sample where the alignment breaks? That would help us reproduce and fix it much faster.
Thanks! :hugs:
As a new member, I can’t add files.
try now :slight_smile:
input.xlsx (12.1 KB)
The request status has been changed to resolved. When and how can I receive a decision? Thank you for your prompt response.
Yes, there really is an issue with text alignment when converting XLSX → ODS. Thanks a lot for the test file — it helps a ton!
We’re actively working on it, but unfortunately I can’t give any timeline yet. I’ll keep you updated right here as soon as there’s progress.
Thanks for your patience!
