How to connect to Claude/ChatGPT for easy hadling my documents and xlsx sheets from the AI to ONLYOFFICE directly?
Hi @EdwinOnly, welcome to the community!
Two options, depending on what you need:
AI in the editors — the AI plugin is already there. Open the AI tab → Settings → Edit AI models, add Anthropic or OpenAI with your own API key. Works in documents and spreadsheets. guide
Claude working with your files from its own app — that’s our DocSpace MCP server: Connect DocSpace MCP server to MCP clients | ONLYOFFICE
Which product are you on — DocSpace, Docs on your own server, or Desktop Editors?
