Community docspace v.9.0.0.168 upgrade to v.9.0.4.50 problem
After upgrading from v.9.0.0.168 to v.9.0.4.50 in the community version, LDAP requires payment
  1. Is this a normal cancellation? I haven’t seen the official update explanation
  2. Where should payment be made and where is the price list?
Same thing happend to me !
Hello @simcyber
Can you share a screenshot with information about your DocSpace in particular? You can find it by clicking three dots next to your avatar in DocSpace > About this program.
Hello @Abdelhak
Thank you for the screenshot. As I can see, you are using version 3.1.1, but the actual version of DocSpace is 3.2.1. Please update your version and check the situation again.
By the way, what installation type did you use? For instance, EXE, Docker. Also, what edition do you use (Community/Enterprise)?
