Clarification: logical values are passed as strings to custom functions declared with any[][] or boolean[][] parameters
Do you want to:
Ask a how-to question / clarify the intended API behavior.
DocSpace version:
Not known. I am using the hosted ONLYOFFICE DocSpace Cloud service:
Type of installation of the DocSpace:
Hosted cloud service provided by ONLYOFFICE. I did not install DocSpace myself, so a self-hosted installation guide is not applicable.
OS: Windows 11
Browser version: Chrome 155.0.8059.85
Additional information:
I would like to clarify the intended handling of logical values passed to JavaScript custom functions.
In the ONLYOFFICE DocSpace web spreadsheet editor, a TRUE cell passed to a custom function with an @param {any} parameter arrives as the JavaScript string “TRUE”, rather than the boolean true. This any behavior was confirmed in the web-based spreadsheet editor.
Additional tests using the unmodified official SDKJS master compared the following parameter declarations:
Parameter declaration Observed JavaScript value for TRUE
any Array element is the string “TRUE”
boolean Boolean true
boolean Array element is the string “TRUE”
The SDK revision used for these comparisons was ONLYOFFICE/sdkjs commit:
9d2138866d929be32f1d107e8b5bfae36156e097
The boolean and boolean comparisons above were performed in the SDK harness; they have not yet been confirmed separately in the DocSpace web UI.
Minimal custom functions for comparison:
(function () {
     * Inspect an any[][] argument.
     * @customfunction
     * @param {any[][]} value Input.
     * @returns {string} JavaScript type and value.
    function PROBE_ANY_MATRIX(value) {
        return typeof value[0][0] + ":value=" + String(value[0][0]);
    Api.AddCustomFunction(PROBE_ANY_MATRIX);
     * Inspect a boolean argument.
     * @customfunction
     * @param {boolean} value Input.
    function PROBE_BOOL(value) {
        return typeof value + ":value=" + String(value);
    Api.AddCustomFunction(PROBE_BOOL);
     * Inspect a boolean[][] argument.
     * @customfunction
     * @param {boolean[][]} value Input.
    function PROBE_BOOL_MATRIX(value) {
    Api.AddCustomFunction(PROBE_BOOL_MATRIX);
After registering these functions, enter:
A1: =TRUE()
D1: =PROBE_ANY_MATRIX(A1)
D2: =PROBE_BOOL(A1)
D3: =PROBE_BOOL_MATRIX(A1)
The SDK results are:
D1: string:value=TRUE
D2: boolean:value=true
D3: string:value=TRUE
Built-in functions still recognize the original cell as a logical value: ISLOGICAL(A1) returns TRUE, TYPE(A1) returns 4, and ISNUMBER(A1) returns FALSE in the SDK tests.
The API documentation lists any, boolean, and boolean as supported parameter types:
Is conversion to a string intended for any parameters? Also, should elements of a boolean argument be JavaScript booleans, as they are for a scalar boolean argument?
If this is intended behavior, could the conversion rules be documented? Otherwise, could you investigate the inconsistency, particularly for boolean?
