Changes in Spreadsheets *Excel are not always saved, loss of data
Document Server version:
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS:
Browser version:
Additional information:
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
I’m using OnlyOffice Excel Spreadsheets
I worked on a table for about 5 hours. The next day, only the beginning of the table remained—90% of my work was lost. This has happened several times over the past month.
During one of these sessions, there was a strange moment where I couldn’t edit the cells. The cell I was working in had red borders, and after about a minute, it returned to normal, and I could continue working. However, neither my work after that moment nor the previous work was saved.
Could this be a bug? Is there a way to prevent this or recover the lost data?
Thank you for your help.
Hello @info.shamanicstudies
This is unusual behavior and we need to take a closer look at it. Please provide us with additional information:
A. The exact product you’re using and its version.
B. If you’re using the desktop app, do you work with local files on your PC or the app is connected to some cloud portal?
In general, the Desktop app has ‘Recover files’ feature: How to recover unsaved documents in ONLYOFFICE Desktop Editors
And the Document server (self-hosted deployment) has the opportunity to restore files from ‘forgotten’ folder in the Admin panel if issues occur during saving to storage.
