Desktop Editor 9.4.0.129;Reporting a bug
Bug: Can’t change page size or orientation (grayed out)
Steps: Open PDF, then File | Print | Select target printer | {bug items grayed out.}
Hello @screeningin
Can you share your PDF file and a screenshot of the dialog? The description is clear, though I cannot reproduce the issue with my regular files, possibly the file itself produces the issue and it is worth studying.
