On onlyoffice, we had issue when about to change the layout size
the default was us letter (dunno why this become the default)
i don’t see the button to change the default setting either.
secondly, i about to change it to F4 Standart. (21cm x 33cm)
but funny enough when i change it. the only page that changed is only current page (not all page)
this is odd since we need to change every page one by one. when we had 100 pages. we will dead changing it one by one. maybe make some button to make it toggleable like
Change all page, or change this page only.
i hope this is become priority since we need change the size almost alot of times to make it standarized.
Thanks for reporting the issue with changing layout size in ONLYOFFICE Desktop Editors! I tried setting custom page sizes in v9.1.0, and it applied to the entire document, so I’m curious to dig deeper into what’s happening on your end. To help us reproduce the problem:
Could you share the version of ONLYOFFICE Desktop Editors you’re using (e.g., check the “About” section)?
If possible, could you provide a sample file where this issue occurs? You can upload it here or send it via private message if it’s sensitive.
Would you mind recording a short video showing the steps to reproduce the issue (e.g., changing the layout to F4 and only one page updating)? You can upload it to a service like Onlyoffice DocSpace/GDisk/kDrive and share the link.
hopefully you can find the fix for this, because yeah… now i forced to install ms office just to change the size layout for all or only some page… maybe if i can give suggestion. when we do the things (change the layout size) you (the only office) ask us to change it only this page or all page… so our job become easier :>
@here, we have found a bug in current behavior with layout change. Basically, selecting all pages or document itself should be changing layout for all pages, but due to the bug it works only with 1 page.
