Cannot add Poe AI Hub
I’ve set up Poe to work with other programs. I’ve copied the base URL and API key. However, I get a “connection error”. I’ve tried various base URL variations. Some AIs have suggested the problem is a CORS issue with your built-in browser. Is there a solution? Is there some template I could use?
:robot: ONLYOFFICE Community AI Assistant
This is an AI-generated response, not a reply from a human moderator. The suggested resources may help, but are not a confirmed fix.
A template will not bypass CORS. If Poe works via curl but ONLYOFFICE reports “connection error,” the likely distinction is that Poe rejects the editor’s browser-origin/OPTIONS request. A CORS-enabled reverse proxy may help, but the forum workaround was not verified specifically with Poe.
Also check your Desktop Editors version: URL-validation fixes for OpenAI-compatible endpoints were released in 10.0.0 under issue #2268. For older AI Plugin versions, custom-provider configuration and /v1 URL handling are discussed here: OpenAI-compatible API issue.
:bust_in_silhouette: Need assistance from a human moderator?
Click the :triangular_flag: Flag option on this post and select Request Moderator Assistance to request a review by the moderation team.
If Poe’s endpoint works from curl but fails inside ONLYOFFICE, the browser layer is the likely blocker. A template won’t change that. Put a small reverse proxy in front of Poe that answers OPTIONS with the editor origin allowed, permits Authorization and Content-Type, and forwards the API key unchanged. Then use that proxy’s /v1 base URL in the plugin. If curl also fails, it isn’t CORS—check the key and exact base path first. Also confirm your Desktop Editors build includes the OpenAI-compatible URL fixes.
Thank you. I appreciate your answer. However, I rarely use the writer. I do my writing with Joplin, so it isn’t worth the hassle to work this out. However, I’ll ask another question about how to use the paid LanguageTool, which would also be nice.
