Hi,
I’ve been using the ONLYOFFICE mobile app to track work tasks in a spreadsheet, and I’m trying to sum total work hours from time ranges (e.g., 09:00–17:30).
On the desktop version I can usually calculate the difference and get a total duration, but I’m having trouble doing the same on the Android mobile app, the formula seems to return a date format or gives unexpected results.
Is there a correct way to calculate hours worked per day and sum them across the week inside the mobile spreadsheet? Or is this a known limitation on mobile?
Appreciate any tips!
Jhonn Marie
