Bug with styling
Do you want to: Report a bug
OS version: Windows 10 x64 (up to date).
App version: 9.0.3.29
Downloaded from: ONLYOFFICE’s website.
STEPS
  1. Create a new spreadsheet (XLSX).
  2. Select all cells (CTRL+A).
  3. Apply a color gradient to the cells.
  4. Apply text formatting (aligned vertically to the middle), left offset of 1.
  5. Select the 1rst row dedicated to the header.
  6. Apply a color gradrient.
  7. Apply these text formats : center horizontally, white color for text.
  8. Select a column.
At step 8, the whole column should apply the header’s gradient.
Video here : https://youtu.be/YtDUyKexVpc
Hi @OnlyFan :handshake:
Thanks a lot for the detailed report — very helpful! And great nickname, by the way :slight_smile:
I’ll try to reproduce the issue on our side and get back to you as soon as I have any updates.
Thanks again for your detailed report. We’ve managed to reproduce the issue on our side, and I can confirm that we already have a bug ticket for this case. Unfortunately, I can’t provide any ETA for the fix at the moment :sweat:
We appreciate your patience and for bringing this to our attention.
Thanks for the return. I’m glad you confirmed the problem. Hope you’ll find a solution soon.
