I’m trying to open mydomain.tld/login. All I get is a Cannot GET /login error. If I open just the domain, I get the default Docs screen.
OK, this is the output of thew egrep:
docspace-ai-service/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-ai/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-api-system/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-api/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-backup-background/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-backup/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-clear-events/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-common/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-doceditor/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-files-services/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-files/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-healthchecks/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-identity-api/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-identity-authorization/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-login/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-management/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-mcp/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-migration-runner/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-notify/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-people-server/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-plugins/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-proxy/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-sdk/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-socket/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-ssoauth/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-studio-notify/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-studio/squeeze,now 3.6.1.560 all [installed,automatic]
docspace-telegram/squeeze,now 3.6.1.560 all [installed,automatic]
docspace/squeeze,now 3.6.1.560 all [installed]
onlyoffice-documentserver/squeeze,now 9.4.0-129 amd64 [installed]
the DocSpace proxy config:
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $proxy_connection;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_hide_header ‘Server’;
proxy_hide_header ‘X-Powered-By’;
proxy_buffering off;
proxy_http_version 1.1;
proxy_buffer_size 128k;
proxy_buffers 8 128k;
proxy_busy_buffers_size 256k;
access_log /var/log/nginx/access-proxy.log;
error_log /var/log/nginx/error-proxy.log;
server {
listen 0.0.0.0:80;
listen [::]:80 default_server;
client_max_body_size 4G;
location / {
proxy_pass http://127.0.0.1:8092;
include /etc/openresty/includes/letsencrypt.conf;
And now that I’m looking at it, shouldn’t it point to port 443 instead of 80? This is the default config file, as I didn’t edit it. Should I?
