Imported from UserVoice
Author: Jason Dech
Hello!
I’m starting to use OnlyOffice desktop editors for linux because it seems to be a closer experience to the Microsoft and Google products. So far so good!
I noticed that your column breaks are part of the first line in the next column instead of the last line in the previous. When I initially put in the column break, it shows up at the bottom of the first column with the style of the next line (screenshot 1).
In other editors, I am able to put this break as part of the last line of text. When I try to do that here, the first line of the next column gets the style of the line that the break is on (screenshot 2).
When I put the column break on the last line of text in the first column, I would expect for the first line of text in the second column to have a different style if I wanted it to (which I do here). I put the break on the last line of text to conserve space on the page - I don’t want a whole line of blank space that could be used by the next section. This is a relatively niche case but it would be cool to see it improved. Thank you for considering!
