Backup/restore of a project in WORKSPACE
HI.
I’d like to migrate a project and all its associated attached files from one workspace server to another.
I did a full export on server 1 and then restored the GZ file to a server(2) with the SAME name/admin user account/IP address.
ALL my folders came back under documents but there is NO sign of the Project
How can I migrate JUST a project
Thanks
Ivan
I see the following data inside localhost_2026-03-10_16-00-51.tar.gz
rwx------ 0/0 631 2026-03-10 16:00 /databases/scheme/projects_messages
-rwx------ 0/0 493 2026-03-10 16:00 /databases/scheme/projects_report_template
-rwx------ 0/0 242 2026-03-10 16:00 /databases/scheme/projects_project_tag
-rwx------ 0/0 870 2026-03-10 16:00 /databases/scheme/projects_milestones
-rwx------ 0/0 454 2026-03-10 16:00 /databases/scheme/projects_templates
-rwx------ 0/0 529 2026-03-10 16:00 /databases/scheme/projects_status
-rwx------ 0/0 720 2026-03-10 16:00 /databases/scheme/projects_time_tracking
-rwx------ 0/0 430 2026-03-10 16:00 /databases/scheme/projects_tags
-rwx------ 0/0 387 2026-03-10 16:00 /databases/scheme/projects_tasks_recurrence
-rwx------ 0/0 341 2026-03-10 16:00 /databases/scheme/crm_projects
-rwx------ 0/0 571 2026-03-10 16:00 /databases/scheme/projects_project_participant
-rwx------ 0/0 242 2026-03-10 16:00 /databases/scheme/projects_tasks_order
-rwx------ 0/0 228 2026-03-10 16:00 /databases/data/projects_project_participant
-rwx------ 0/0 247 2026-03-10 16:00 /databases/data/projects_tasks_order
-rwx------ 0/0 765 2026-03-10 16:00 /databases/scheme/projects_projects
-rwx------ 0/0 307 2026-03-10 16:00 /databases/scheme/projects_following_project_participant
-rwx------ 0/0 409 2026-03-10 16:00 /databases/data/projects_projects
-rwx------ 0/0 138 2026-03-10 16:00 /databases/data/projects_following_project_participant
-rwx------ 0/0 331 2026-03-10 16:00 /databases/scheme/projects_tasks_links
-rwx------ 0/0 443 2026-03-10 16:00 /databases/scheme/projects_reports
-rwx------ 0/0 563 2026-03-10 16:00 /databases/scheme/projects_comments
-rwx------ 0/0 142 2026-03-10 16:00 /databases/data/projects_tasks_links
-rwx------ 0/0 567 2026-03-10 16:00 /databases/data/projects_reports
-rwx------ 0/0 9084 2026-03-10 16:00 /databases/data/projects_comments
-rwx------ 0/0 656 2026-03-10 16:00 /databases/scheme/projects_subtasks
-rwx------ 0/0 5785 2026-03-10 16:00 /databases/data/projects_subtasks
-rwx------ 0/0 282 2026-03-10 16:00 /databases/scheme/projects_tasks_responsible
-rwx------ 0/0 1168 2026-03-10 16:00 /databases/scheme/projects_tasks
-rwx------ 0/0 1542 2026-03-10 16:00 /databases/data/projects_tasks_responsible
-rwx------ 0/0 13439 2026-03-10 16:00 /databases/data/projects_tasks
Hello @ivan
Unfortunately, there’s no way to migrate only one module. The Workspace restoration process takes all data from the backup file.
So, we need to focus on checking the root cause of the issue. Could you please share Community server and Control Panel logs folders from the new server once the migration process has been completed? First of all, we need svcBackup.log file, but entire folder is better.
One more thing, please confirm that both portals have the same component versions (Community server, Control Panel, etc.). This is critical for a successful migration. Also let us know your exact OS and Workspace installation type (docker\packages).
Hello Alexandre. I decided to MANUALLY recreate the project as people were wating. I will try the experiment anotghe time. Im sorrY i kept you waiting.
Please close ticket
