Autotext featura
Hello;
I would like to suggest an autotext feature in Docs.
In this feature, the user can start typing some prechoosed characters, and onlyoffice offer the possibility of a whole paragraph, or a complete text.
That will help the users that write the same text in a document very often, and to automatize tasks in the software.
Thank you in advance.
Hello @Cristiano
Did you have a change to utilize such feature in any other document processing app? If so, can you provide a link to the documentation that describes the process of configuring it?
Hello @Constantine
Thank you for the reply, that feature is also called “Quick Parts” on MS Word, see in the links below how it works:
https://wordmvp.com/FAQs/Customization/AutoText.htm
Thank you @Cristiano
We have added your suggestion to internal tracksystem, we’re working on it already.
do public can see the list feature that ongoing to be added and not yet planned? maybe we can suggest another else since alot of OP feature on ms office need to be added on onlyoffice
Hello @DNA
I’m afraid there is no public roadmap available yet. If you have any features to suggest, please create separate topics for them in Suggestions category or respective subcategories:
allright then, thanks
