Device: Pixel 7 Pro
OS Version: Android 16
App Version: 9.0.2
Okay, so I will keep this specific to one VERY broken thing.
The keyboards. I have tried three different keyboards and none of them work properly.
First of all: There is no spell check or autocorrect in Only Office. The document itself doesn’t spell check and two of the three keyboards I tried didn’t even show their built-in autocompletes.
Swiftkey is my main keyboard and it simply doesn’t show the auto-complete row.
Gboard has the same problem.
Then there’s Futo.
Futo is interesting because it DOES show the autocorrect line while Gboard and Swiftkey don’t.
I tried turning spell check on and off in the app. That is broken too, by the way. It doesn’t toggle when tapped. If you exit the menu and return, it does show it as having turned on or off - but it’s not clear that anything actually changed.
I made a video of what’s happening but I can’t upload it because my account it too new. I’d be happy to share it once I’m able. If you need any other info, let me know. I’d like Only Office mobile to work. The desktop app is nice! But this issue renders the mobile version unusable.
There’s other stuff that needs fixing in the app, but this is the deal-breaker. The other stuff just needs improvement and iteration.
Hey, @FoxWarder !
We’re aware of the issue with the spell checker not working, and we’re currently working on a fix. We apologize for the inconvenience. You’ve been added to the list of users waiting for this fix, and you’ll be notified as soon as the issue is resolved.
As for the keyboards’ incorrect interaction/behavior, we’ve increased your community level — you can now attach video files. I’m waiting for your video so we can continue investigating the issue.
https://www.swisstransfer.com/d/10e4f368-4ba8-4820-8944-14d10f546816
It would seem the file is a little over your size limit. Here is a link where you can download the video from.
Hello!
Thank you for providing it to us. It’s currently being analyzed.
Hi again, @FoxWarder !
The thing is, we don’t actually support the autocomplete function right now. Some keyboards, like Futo, simply ignore that fact.
For now, I can say that we are working on adding auto-complete support to our mobile editors. We will notify you as soon as this feature is available.
Me too!
I see the same behaviour as FoxWarder when trying to enable the spell checker - the toggle doesn’t change when tapped but exiting and re-opening the menu shows it is enabled. But after that, no spelling errors are flagged.
This happens on both Lenovo TB336FU tablet and Pixel 7 phone
Both are Android 16 with OnlyOffice 9.4 on the device
Hi @Chris2527
I appreciate the report.
I will provide an update once the issue has been resolved.
