Animations paragraph by paragraph
I would like to create animations paragraph by paragraph, but I can only manage it for the entire content placeholder.
I don’t know if it’s possible.
It seems it’s possible because when I import a PowerPoint presentation into OnlyOffice, the paragraph-by-paragraph animations work, but I don’t know how to create new ones.
I am on Mac OS and using version 9 of OnlyOffice.
Thanks !
Hello @JJonly
Do I understand that you are describing functionality discussed in the topic below?
Hello @Constantine
Yes, that’s exactly the same thing.
Sorry, I looked for it but I haven’t found this topic yet…
So, I’m looking forward to this improvement.
Thank you !
Thank you for the reply. Your vote will be forwarded to the suggestion. Once it becomes available, I will notify you.
