After search focus not set to first occurrence
ONLYOFFICE Mobile: Documents
Do you want to: Report bug
Device: iPad 2022
OS version: iPadOs 26.4.2
App version: 9.3.1
Mode: Connect to Cloud
Additional information: bug seems to occur in all my spreadsheets, large or small. The sheets are originally exported from google sheets as .xlsx
Bug: When I ask the app to search a spreadsheet for a text string it correctly reports the number of occurrences found for that text string. But the focus is not automatically set to any if these occurrences, so I have to scroll through the spreadsheet myself to find a highlighted cell. This is of course not correct behavior of the app.
Henk11](/u/henk11)
Additional remark removed.
Additional information: in a new spreadsheet, so not exported from google, the same bug appears. So no focus on a found cell. The web editor shows correct behavior in this case.
Hello @Henk11
I can confirm that this behavior is a bug, it is registered under the number 79397. I will keep you posted on the details.
