Hi,
I already connected my Nextcloud Connector to my document server and activated the advanced permissions settings in the administration panel. When i share a document with another person, the advanced tab is visible, but it is completely empty, even if I already made a share to a person.
Does anybody have an idea to solve this problem?
Best regards
neibeck
I forgot:
The document server runs on NextcloudPi (RaspberryPi 4 Model B) V1.56.0
Operating system “Linux 6.12.58-current-bcm2711 aarch64”
Nextcloud Hub 9 (30.0.17).
OnlyOffice Connector App is V9.11.0
The document server is V9.2.1-8.
Hello @neibeck
Thanks for the details. We’ll run some tests from our end in that matter, please await my feedback.
We were able to reproduce the issue, but I have to mention that NC 30 is in EOL status, it is not supported by the developers anymore. Also, latest version of the connector app (9.12.0) also does not support NC 30.
In such case I recommend updating NC to any supported version and the connector app to version 9.12.
Follow-up: have you shared a document via Share tab before opening Advanced?
