Adjustable speaker notes text size in Presenter View
It would be very useful if ONLYOFFICE Presentations included the option to adjust the text size of speaker notes in Presenter View (for example, through a zoom control or font size setting). This feature is available in PowerPoint and LibreOffice Impress and is essential in presentation contexts: when the device is positioned at a distance from the presenter, it’s necessary to increase the text size for comfortable reading; conversely, when the device is closer, reducing the size can be more convenient. Adding this option would significantly improve the accessibility and usability of the presenter mode.
Hello @Juldac
Thank you for the suggestion. We need some time to review it, please await my feedback.
I was informed that this suggestion has been registered. Once it becomes available, I will let you know.
Hi, I am sorry but I do not see a presenter’s mode at all. It looks the same as the diashow. In this context, I am also not able to print notes, just the slides. Can you please advice? Thank you!
Hello @annasch
This article describes all possible options for viewing a presentation, including usage of the presenter mode:
