Add trusted source for file:// hypertext link
We use xlsx files with a lot of file:// hypertext link. There is a warning window every time you click.
Would it be possible to add a whitelist feature?
Thanks
Hi, @Benoit33260
To check what can be done in your case, please send:
  • A sample .xlsx file that reproduces the issue (with non-sensitive data).
  • A short screen recording (or at least a screenshot) showing: clicking the file:// link → the warning window text → what happens after you confirm.
example.xlsx (8.8 KB)
Hello, thank you for your reply. Here is a sample file and the screenshot I get every time I click on a link:
The link is: H:\Informatique\Commun\PLANNING\PLANNING%202026.xlsx
Thanks
Hello, @Benoit33260
Thank you for the details and the sample file! We have registered your request in our internal tracker — your case has been added to an existing bug related to the warning dialog behavior when following hyperlinks.
Unfortunately, we don’t have an exact ETA for the fix yet. We’ll update this thread as soon as we have any news.
