Please describe your suggestion as detaileIt as possible. You can also draw a scheme or attach images and videofile to the post (or to place them to external storage).II wonder if there are obstacle in adding OnlyOffice in the Microsoft Store like mobile apps. It would be great for small organizations .
Sorry but with Safari I was not able to add description in the post itself. I would be great install Desktop App from the MS Store for small organizations. I wonder if there are licensing or store fee issues.
Hello @luca
Let me get more information on that query. I’ll keep you posted.
Hello @Constantine,
thank you for your message.
My suggestion is to add OnlyOffice Desktop to the Microsoft Store like OnlyOffice mobile apps on the Apple Store and Google Play store.
The advantage is, especially for small organizations, like mine.
Apps on official stores look more reliable, and it’s easier to convince the management about their adoption than of Microsoft Office.
Moreover, software updates are in the background and even more straighforward than check at opening.
There are other office suites on MS Store, so probably there aren’t big issues doing that.
Hello @luca
If you don’t mind, I will join this thread as well.
We’re checking the possibility of your suggestion, and we will update this thread once we have something to share.
@here, we have published ONLYOFFICE Desktop Editors in Microsoft Store:
Please check it out.
Very happy! Thanks. I hope that you will have a great feedback from many other users.
Kind regards.
Luca
Thank you for the kind word. I am closing the topic as solved.
