Suggest a feature
OS version: Windows 10
App version: Community version 9.3.1.8 (x64 exe)
Additional information: While printing there is no option to print pages as odd and even, as many of us have only single side printer at home for printing double side in that printer gets easy when we use odd pages and even pages. Can we get this feature include in OnlyOffice? if yes please add this in newer version so.
Hi @RAHUL_THAKRANI, welcome to the community, and thanks for the detailed suggestion!
This request is already registered as an enhancement and being tracked internally(track number- 72465).
We’ll post an update in this thread once there’s news on implementation.
Hi @RAHUL_THAKRANI ,
In the meantime, an option may be to export your document to a .pdf
The application that opens that .pdf may have an option to print only odd, or only even pages. I’ve seen that option in the application I use, being PDF-XChange, but I would expect the Adobe version would support that function too.
From experience, I have never had to use that option as I have always had a duplex printer. So I cannot attest to its usability.
It is only a work-around, but may be easier or faster than other alternative solutions.
Greetings,
As a Linux User i don’t always get the privilege to have proprietary drivers for my old printer so in order for it to work i often rely on open source drivers which don’t always necessarily provide the best features possible such as the ability to take double sided printouts, in order to do that having the ability to manually switch between odd and even pages would be helpful.
Thank You
I’ve merged your topic into this existing thread, as both requests concern printing odd and even pages separately for manual double-sided printing. I’ve also added your request to the corresponding enhancement in our internal tracker, noting your additional suggestion to print pages in reverse order.
We’ll update this thread when there’s news on implementation.
