OS does not seems to matter. doesn’t work (anymore) on Windows 11 and fedora 43 budgie. OO Version 9.1
Thank you @theking2
We’re checking the situation. I will contact you shortly.
Hello @theking2
Is this version of the connector app still used? If it is, please update it to the actual version 9.1.1. You can update it from Apps > Active apps or Update sections.
Hello @theking2
The desktop app v.9.2 has been released. Please update the app and re-check the situation. Please let us know the result.
the situation did not change.
I could be of more help if someone can disclose where the infomaniak cloud registration is stored. Is it in the registry, in a config file and if it is where?
Understood, we need some time to check the situation. I will contact you shortly.
Dear @theking2
Please confirm that you updated the connector app and let us know its current version. Please make a screenshot of the connector app in the Apps > Active apps.
No, we previously mentioned that this app isn’t related to ONLYOFFICE: Add nextcloud permanently - #15 by Alexandre
Please install the official connector app and re-check the situation.
