Add indicator to show Copying vs. Moving when dragging hi-lighted text in Document section
In the document editor, hi-light a block of text. Click on text block and drag to a new location; this moves the text. If you hold down the Ctrl key and drag the text block it will be copied. If would be handy if, when holding down the Ctrl key, a “+” sign appeared indicting the copy function. This is the case in MS Word.
We are currently analyzing your suggestion, thank you for sharing!
We’ve added your proposal to our tracking system. I’ll inform you as soon as a version with this feature is released
