Add arrange shortcuts to presentations
I couldn’t find any shortcuts for the “arrange objects” option (Presentation Editor - Align and arrange objects on a slide). In Google Slides I got used to Ctrl+Up/Down to do it, but ideally it should be configurable.
For Google Slides: Keyboard shortcuts for Google Slides - Computer - Google Docs Editors Help
Command Shortcut
Send backward Ctrl + Down arrow
Bring forward Ctrl + Up arrow
Send to back Ctrl + Shift + Down arrow
Bring to front Ctrl + Shift + Up arrow
For MS Powerpoint: Use keyboard shortcuts to create PowerPoint presentations - Microsoft Support
Command Shortcut
Send backward Ctrl + [
Bring forward Ctrl + ]
Send to back Ctrl + Shift + [
Bring to front Ctrl + Shift + ]
For LO Impress: Shortcut Keys for LibreOffice Impress
Command Shortcut
Send backward Ctrl + “-”
Bring forward Ctrl + “+”
Send to back Ctrl + Shift + “-”
Bring to front Ctrl + Shift + “+”
Hello @jrom
We’re checking the request. I will contact you shortly.
Dear @jrom
We have added your request to internal tracksystem, we have started working on it.
Thank you for your suggestion!
