Add a project structure for organizing multiple documents of different types into a coherent project
Imported from UserVoice
Author: Cedric Montiel
I use text editors and spreadsheets for world building and writing stories. It ends up being gigantic projects with hundreds of thousand of words, multiple tables, pictures, external links, pictures, etc…
I would love to be able to separate the various parts of the background in multiple documents of different types. Think for world building: a different file for each region or country, another or several other for the different factions, a table for the resources available per region or faction, maybe another for a relationship graph, etc…
Ideally, it would largely resemble the headings list in the left panel, but with a ability to reference external files as well as headings in this document.
It should also be possible to use relative links within the project, so if you move the folder for any reason, you don’t get dead links as long as the structure remains the same inside the folder
This idea sounds like Creative Writing Mode that we discussed earlier: Feature Suggestion – A Creative Writing Mode for OnlyOffice (with a twist!)
If it’s possible, please confirm that I understood it right.
