Greetings to everyone; I recently installed the software on my Android device, and when I attempt to use accents on letters, particularly since I use Spanish, they do not function with an external keyboard that works perfectly in other applications, so I would like to know if there is a way to resolve this issue or if it is a feature that has not yet been implemented, and I have attached a demonstration video where I type the same sentence side by side in OnlyOffice and my web browser.
ONLYOFFICE Mobile: Documents
Do you want to: Suggest a feature / Report a bug
Device: Lenovo TB311FU
OS version: Android 16
App version: 9.2.2, build 683, SDK 9.2.1.4 3
Mode: On Device
Additional information:
https://we.tl/t-FuczogaVmG
Hello @alepav
It seems that the link has expired. It is possible to share a new one? Also please specify which external key board is being used.
Sure, here’s the demo video:
The keyboard is a generic keyboard. It works perfectly outside of OnlyOffice.
Thanks for the video. We will run some tests according to the provided information to confirm the issue. Please await my feedback.
I have the same problem. After some testing, all the accents work well in mobile mode, either in portrait or landscape screen when writing through the digital keyboard. When using the Samsung DeX mode, no accent symbol is recognised, not even the ~ when writhing the “ñ”. Hope this help to find the problem.
@here, QA has confirmed the bug in current version of the mobile app. It is now registered under the number 80369 in our internal bug-tracker and being processed. I will keep you posted on the news.
I sincerely appreciate your feedback
A new version of OnlyOffice has been released and the problem persists
Unfortunately, it still hasn’t been fixed.
we have released v.10. This release contains a fix for the described situation. The mobile apps update will be available soon.
