Will OnlyOffice support Nextcloud 34.0?
The latest version of Nextcloud 34.0 has been released. I tried to install the compatible OnlyOffice plugin from the Nextcloud App Store, but the plugin only supports up to Nextcloud 33.0. Since I’ve installed Nextcloud 34.0, I can’t use OnlyOffice. Will this issue be resolved in the future?
btw: activating onlyoffice-nextcloud 10.0.0 breaks nextcloud 34
Yes, I’ve encountered this situation as well.。。。
I have the same issue and would be interested in any updates or info on when this might be fixed.
An update has been released and is now working for me
Not sure if multiple things happend at the same time but there is at least one other problem that caused OO not working in Nextcloud and that is actually client sided and called uBlock origin. OO now uses a library called Analytics.js and paranoid as uBlock origin is it blockes everything with the word Analytics in it. DIsabling uBlock or disabling it for cloud.example.com as well as office.example.com solved the problem for me and I now have a working NC/OO combo.
It could be that OO newly includes an Analytic library :person_shrugging:
Hello @theking2
Thank you, the fix for this behavior ( uBlock origin\Analytics.js) will be included to the next Document server Community edition release (v.9.5)
@wc19888 @jim1 If there’re still any issues with Nextcloud v.34, please let us know.
Hi @Alexandre,
I’ve had no further issues since updating to the latest version, so all good from my point of view.
Thanks for checking back.
