Using AI Agents on Spreadsheets – Community Help
Hi everyone,
I’m trying to figure out how to properly use the Ai Agent in ONLYOFFICE spreadsheets as a part of my workflow, but I keep running into issues.
The main problem is that I can’t get the Ai to actually edit or create rows and columns from scratch. When I give a prompt, the chat box says the Ai completed the action, but nothing changes on the spreadsheet itself.
The only partial success I’ve had is using the =Ai("') function inside of a cell, but even that is inconsistent and glitchy.
When doing it from inside a cell using the =AI("")prompt inside the cell I get
I’ve been reading through other forum post from the community and watching ONLYOFFICE Official YT videos . In the video , it looks like you can edit and create content with prompts, similar to how Gemini AI works incorporated into Google Workspaces like Sheets or Docs. That is exactly the workflow I’m trying to achieve.
Provider not available error - #10 by zd_admin
https://www.youtube.com/watch?v=n7mGKDl69no
What I’ve tried so far:
  1. Spent a few days setting up API keys through OpenRouter.
  2. Made sure I had a valid, whitelisted API for GPT-5.2 ( as recommended in previous forum post ).
  3. Also tried another Ai promoted on the YT vide I posted “DEEPSEEK” both gpt and deepseek where from openrouter
  4. set up the AI in both Main Tab of ONLYOFFICE and through individual spreadsheet AI tab section → settings
and in the actual spreadsheet that I’m trying to work I have had to manually add the Ai under AI tab then settings and have it set up
What I’ve learned from the forum:
Marix (a forum helper) mentioned on June 9th that DeepSeek currently has issues with the ONLYOFFICE AI Agent, and that support is limited to a handful of compatible models. GPT-5.2 was listed as one of them. That’s why I focused on getting that one working.
The problem:
Even with GPT-5.2 properly set up through OpenRouter, the AI still doesn’t modify or edit spreadsheets the way the video suggests it should. It acknowledges prompts but doesn’t execute changes on the actual data.
My question to the community:
Has anyone here successfully integrated the AI Agent into their spreadsheet workflow? If so:
  • Which provider/model are you using?
  • Are you able to get the AI to create or edit rows/columns based on prompts?
  • Is there a specific setup step I might be missing?
I’d really appreciate any insight or guidance. I feel like I’ve tried everything at this point and I’m honestly lost
I could not attach images. So I created the same Post but on reddit so images can been seen
https://www.reddit.com/r/OnlyOffice/comments/1v0ryos/using_ai_agents_on_spreadsheets_community_help/
Hi, thanks for the detailed writeup. Quick note first: the video isn’t misleading — the pivot-table flow works on the current release, I reproduced it on my side.
What doesn’t work on the current build are the simpler direct edits (“set A1 to 100”, “insert 42 in C5”, etc.) — the Agent reports success but the sheet doesn’t change. I tested the same prompts (same API key, same model) on the upcoming release and they went through and edited the sheet correctly. So it’s a build-side issue, not a setup problem on your end, and it’ll be sorted in the next release.
Thank you and I can’t wait for the team to release it. Its reassuring to know that it was not a set up on my end. Any timeline on when this can be released ?
Glad it helped. We don’t have a public ETA to share, but I’ll drop a note here once the release is out.
Hi @anyforums,
As promised — 10.0 is out. In this version the AI Agent and AI plugin were combined into a new AI Tools module, and direct edits like “set A1 to 100” or “insert 42 in C5” should now actually change the sheet. Checked on our side in Desktop Editors 10.0.
To try it:
  1. On the start screen click AI Tools in the left panel → Accept & Install.
  2. Add your model in Settings → AI Models.
  3. Open a spreadsheet → AI Tools → AI Chat.
Let us know how it goes!
First of all thanks for keeping tabs and writting back that means so much .
Hey so I did check and I see ChatGPT is by default. My lead question is would other supported models work like Claude, or Gemini , Deepseek ect?
Hi @anyforums,
Glad it’s working for you! Yes, other providers should work too — Claude (Anthropic), Gemini, DeepSeek, Mistral and others. In Settings → AI Models, add a new model, pick the provider from the list and enter your API key from that provider.
Results can differ a bit between models, so if one doesn’t edit the sheet as expected, feel free to try another one.
More details here: Configuration - ONLYOFFICE
