Do you want to: Report a bug (Suggest a feature)
OS version: Windows 11
App version: v9.2.1
There is a behavior of the Spreadsheet program whereby the cell you have been typing in “loses focus”. I don’t know if this is a bug, but it is a feature that I think would be optimal to not happen.
For example, say you are editing any cell, and you are typing a formula, and part of that formula involves another cell, e.g. “=1+F5+73”.
The expected behavior:
- user selects cell, e.g. A1 with mouse
- user types F2 and starts to edit cell
- user types: =1+
- user uses mouse to select F5, so now it is: “=1+F5”
- The “focus”/cursor should still be inside A1.
- user types: +73
- user types enter and completes the formula.
What happens instead in OnlyOffice:
- after step 4 above (selecting a cell to input into the formula with the mouse), OnlyOffice “loses” the focus away from the editing cell
- now, if you continue typing to complete the formula, nothing happens, because the “cursor”/“focus” is “gone” (don’t know how else to describe this). This is despite the fact that you were just editing cell A1 in the middle of a formula.
- in order to continue editing the formula, you need to use the mouse to select again the cell you were editing (my example above A1), and then you complete the formula.
I don’t know if the above behavior was intentional or not, but I find that it really impedes entering formulas efficiently.
A related problem (maybe linked to the same code), is that if the user temporarily switches out of OnlyOffice in the middle of editing a cell to another program, and then comes back, the “cursor”/“focus” is also taken away from the cell you were editing. Again, this impedes entering formulas efficiently.
e.g. say a user is editing a cell, and wants to cut and past a value from the web browser into the formula, it is not possible in a seamless way.
So the expected behavior would be as follows:
- user edits a cell, e.g. A1, and starts typing: =56+
- user switches to the other program (e.g. does ALT+TAB) into e.g. a browser, finds the value they want, selects and it and copies it, e.g. say this value is 7.866.
- user switches back to OnlyOffice with ALT+TAB.
- user presses CTRL+V to complete the formula: =56+7.866
Instead what happens is, upon step 3 switching back to OnlyOffice, the “cursor”/“focus” is gone from A1. So pressing CTRL+V doesn’t paste anything into anywhere, nor is typing doing anything, despite that you were just editing cell A1 in the middle of a formula. You need to explicitly select cell A1 again with the mouse, then you can continue on with step 4 above.
Again, I don’t know if this behavior was intentional, but I find it impedes efficient entry of formulas using the keyboard.
Please do let me know if this description was not clear. Thank you!
