To be able to choose which folder is opening when going to docspace on the web
Imported from UserVoice
Author: Peter Nathschläger
I would like to be able to configure, which folder is being opened when going to my doc space online. Actually it opens “Rooms” But I do have my files in a different folder.
In next release you will be able to select custom section after entering DocSpace in your profile > File Management > “The start section at the entrance” option.
