Spreadsheet "comments" glitch
Do you want to: Report a bug / Ask a how-to question
DocSpace version:
Type of installation of the DocSpace (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS: Linux Fedora 43
Browser version: Waterfox
Additional information: Regarding OnlyOffice with a pre-existing excel file. just updated to the new OnlyOffice version 9.3. My older OnlyOffice version worked great with this same document no problems at all. With Version 9.3 I am seeing a glitch in which all my previous comments no longer have the user name on the comments, but has various other numbers/letters (actual example: tc={24d7b50e-9995-d806-9b2-4f565f8d68fe} followed by the date/time. Each comment has a different user name number/letter code. I can edit each one to the correct user name, and save them again, but when I close the spreadsheet and then reopen it, the comments all revert back to the number/letters code and I have to edit all comments over again for numerous comments.
Is this a glitch in the new update to 9.3 for any others and what can I do to keep the “comments” correct user information “saved” so I do not have to keep repeating this each time I reopen the spreadsheet?
(I do like the new left side “comments” column; it is helpful for finding specific comments!)
Hi! Thanks for the detailed description.
If you’re using a self-hosted DocSpace installation, please update to 9.3.1 and re-check the same file (a fix for this behavior was delivered in the 9.3.1 maintenance update): CHANGELOG
If the issue persists after update or if you’re using ONLYOFFICE DocSpace Cloud, please attach a short video showing the full flow, so we can reproduce it on our side.
Hi Marix, Thank you so very much for replying!! The update to 9.3.1.8 works! When I add new comments, it will now include the author/user name’s name in new comments. I also was able to edit the existing comments and just by clicking OK, the name changes back to the correct original user name/author. When I save and close the document, and then re-open it, it now keeps the user name/author!
You are all amazing. Thanks so much!!!
Hi! Thank you for the update — I’m really happy to hear that upgrading to 9.3.1.8 resolved the issue and that the author names in comments are now saved correctly after reopening the file.
​Thanks again for taking the time to test and confirm the fix. If anything else comes up, feel free to start a new thread and we’ll be glad to help!
