Spreadsheet colum width
So, from what I can gather the spreadsheet uses points for row height and symbols for width… While this may be the standard for all programs, is it possible to change the units to cm or inch? I know excel can do that, and I much more often use cm than symbols… and I have no idea how many symbols there is to a cm.
And if it can’t, I really suggest it should be able to.
Can anyone help?
Hey @Christofferj, :wave:
Thanks for the suggestion!
I’ll pass this along to our development team for consideration. I’ll keep you updated if we make any progress on adding this option.
I would prefer the option for mm/cm too. In MS Excel i have done some templates for e.g. Lables and got some from printable Lable distributors. With OnlyOffice i cant use them anymore because the messurement of the cells does not fit anymore.
Hello @Christofferj and @NScale,
@NScale, I’ve responded to your query in this thread: Cell Wide and High in cm/mm Possible?.
@Christofferj, could you take a look at that same thread to confirm if we’re talking about the same feature (e.g., setting cell width/height in mm/cm like in MS Excel’s Page Layout view)? This’ll help us ensure we’re on the same page and can consolidate the suggestion.
Appreciate your feedback! :hugs:
