Smart Art to rigid
Hi,
We use in my Cie OnlyOffice Desktop Editor and OnlyOffice web in Infomaniak kDrive.
SmartArt in ONLYOFFICE appears limited in structural editing: a layout with 3 items cannot be easily converted to 2 or 4 items. Like for Processus or Hiérarchie groups where SmartArt are preconfigured with few options of differents nodes. If we need to add an other node, it’s not possible, except if we heavily manually modify the Smart Art.
This makes the feature impractical for real editing, because users must recreate the object instead of simply adjusting its number of elements.
Could we gain parity with MS Office on this aspect ?
Thanks and best regards,
Hello @louisfiacre
Thank you for the suggestion, it is registered under the number 60267. Once it gets implemented, we will notify you.
