Report a bug
I have an Excel file that contains matrix formulas, which worked perfectly a few months ago. However, since the latest versions of OnlyOffice, when I open this file, the matrix formula no longer calculates automatically.
I need to go to the affected cell and press CTRL+SHIFT+Enter to update the formula. As long as the file remains open, the formula works correctly. But if I close and reopen the file, the error reoccurs.
I have attached an example file for your reference.
In the “Input” tab, when entering a value greater than 10 in cell B2, you can observe the results in cells B5 and C5. No matter what value is entered in B2, the results in B5 and C5 are not updated.
Hello
Do you have a workaround in order to work on ipadOS ? As there is no F9 key, what can be done ?
I have tried to add an automatic macro to refresh the sheet and formula but macro do not work on iPadOS.
Many thanks for your help.
Kind regards,
We have just released version 9.3 of Documents app for iOS that contains fix of the issue mentioned in this topic. Please update the app and provide a feedback.
