Set default document layout for new documents
Imported from UserVoice
Author: Matty Byers
I’m using OnlyOffice on a TrueNas instance.
I want to propose being able to set the default layout for when a new document is created.
I found we can replace the new.docx file however this is extremely and overly cumbersome.
An example might be that a user will want every new document to be A4 size with narrow margins and a certain font without having to set it up each time they create a new document.
Thank you.
Author: dabdiel
e.g. default font to use (It’s a bit of a hassle to set my preferred font instead of Arial everytime), page border, etc.
