"Save As" to Docspace?
I’m new to OnlyOffice and I’m using it on a Windows 11 PC. If I open a document stored on the local drive, I can’t seem to save it to my docspace from within the opened document. I have to copy it from my local drive to the docspace first. It feels like there should be some kind of “save as” or “move” feature to allow me to save an open, local document to my docspace, but I can’t seem to find it. What am I missing?
My current workflow:
Download document > Open in OnlyOffice > Save to local drive > Open OnlyOffice Docspace > Open Explorer > Drag document from Explorer to Docspace > Open document from Docspace > Start working in Docspace document
My desired workflow:
Download document > Open in OnlyOffice > “Save As” to Docspace > Start working in Docspace document
I did search for this issue and didn’t find anything that answered this specific question. If the answer exists somewhere in the community, I’d appreciate it if you’d point it out. Thanks for your attention.
Hello @rdp
Your idea sounds interesting. We’re checking it out. I will contact you shortly.
Hello @rdp
Unfortunately, we’re not sure that the requested feature would be a good solution. The desktop app allows you to connect to many different portals, not only to DocSpace. In such a scenario (Download document > Open in ONLYOFFICE > “Save As” to DocSpace > Start working on the document in DocSpace), it would be unclear which portal should be used to save the file.
However, we’re already working in this direction, but from a different angle. We’re going to implement full synchronization between files in the cloud and local files (internal tracking number: 59342). I believe this will resolve your case as well.
Hello @rdp
We have decided to register your suggestion and have started working on it. We will contact you once we have something to share.
Thank you so much for considering it. I’m a software product manager and I know that these kinds of requests can be a real pain. If there is anything I can do to help (providing more context for a PRD, more detailed workflow, beta testing, etc.), please let me know. I’d love to contribute.
All the best to you!
This particular request is already being worked on. We will keep you posted.
However, there are ways to contribute, and we always welcome contributions: Help us make ONLYOFFICE better | ONLYOFFICE
