OnlyOffice Desktop Editors 9.3.1.8, Windows x64.
When I insert an OLE object (Insert → Object → spreadsheet) into a document, the embedded object renders as a low-resolution bitmap. This is visible in the editor at any zoom level, and carries over to PDF export — making text inside the object blurry and unsuitable for client-facing documents.
Request: render embedded OLE objects at higher DPI, or at least at print resolution (300+ DPI) during PDF export. Ideally expose a quality setting in advanced settings.
Use case: Word-style invoice template with embedded spreadsheet table for line items and formulas (subtotal, VAT, total). Currently unusable because of rendering quality.
Thanks, Roy
