Downloaded amd64.deb version of ONLYOFFICE. Tried DeepSeek API in the document AI tab and it worked fine.
But when I added the same API key to the ONLYOFFICE AI Agent, it showed “Provider not available” error.
Thank you for your message.
To clarify the situation, please tell us which ONLYOFFICE product you are using exactly (for example, Desktop Editors, ONLYOFFICE Docs, DocSpace, etc.) and its full version number.
Please also describe how exactly you are trying to add DeepSeek to the AI Agent: which menu/settings section you open, which provider option you choose there, and at what exact step the “Provider not available” message appears.
At the time of posting the message, I was using the Desktop Editor debian version latest. I am unsure which version it was, considering 9.4 was released today.
I have since uninstalled it and reinstalled the flatpak current version 9.3.1.8 Desktop Editor (community version).
As for adding the AI, theres an AI Agent tab on the bottom left side right above the Settings button.
I click on it. Click on Add provider button. Select DeepSeek from the Provider dropdown menu. Enter “DeepSeek” as name. Enter API key. And then click on Add Provider button on bottom right.
And then I see the image I posted before. A red mark in front of the name. And when I hover the mouse over it, it says “Provider not available”.
Thank you for the details. The steps you described look correct, and DeepSeek is listed as an available AI Agent provider in ONLYOFFICE Desktop.
Could you please send us a screenshot of the Add provider window exactly as you fill it in, with the URL field clearly visible and the API key masked?
Please also let us know whether you are using any proxy, VPN, firewall, DNS filtering, or antivirus/SSL inspection on your computer or network, as these may affect provider availability.
Please also check from your computer whether the DeepSeek endpoint is reachable from the terminal.
On Linux, you can test it with:
curl -I https://api.deepseek.com
And please verify that your API key is still valid on the provider side as well.
Thank you for the clarification.
Could you please try one more test: when adding the provider in AI Agent, leave the Name field unchanged and save it as is?
If the same error still appears, please let us know.
Thank you for your patience, and sorry for the delay.
We are currently checking this behavior on our side. As soon as we have any update or more information, we will post it here.
Sorry for the delayed reply, and thank you for checking this on another platform too.
We checked this on our side. At the moment, AI Agent supports only a limited number of providers and models. Support depends on the provider and on how its API works, so not every provider or model is compatible.
DeepSeek is not working reliably with AI Agent at the moment, and this may change depending on updates on the provider side.
Also, not all models are supported yet. For example, on our side, the currently supported OpenAI model is GPT-5.2. The list of supported providers and models may also change over time due to API changes on the provider side.
