Problem ? with text vertical alignment in a cell
Hello
In a table, in one cell, the vertical alignment is not respected:
I looked at all the parameters that seemed to be relevant but I’m unable to find a cause :frowning:
The file:
chess set to print.docx (204.4 KB)
Thanks for your analysis !
Hello @arcqus
Thank you for the file. We are running some tests with it, please await my feedback.
This issue has been registered as a bug. Once it gets resolved, we will notify you.
