Printer Orientation
Do you want to: Report a bug
OS version: Windows 11 Pro 22H2
App version: 9.1.0.167 (x64 exe)
Downloaded from: ONLYOFFICE website.
Additional information:
The bug has to do with documents not printing to the landscape orientation during printing with the native print dialogue. When It happens in the be at random, HOWEVER whenever it happens to a specific document, that document permanently has the problem.
It does not matter if I set the Layout settings to Landscape or not; and it does not matter if I choose landscape in the onlyoffice native print settings (which on a side note CHANGES the actual document layout orientation).
It only seems to work when I use the System Print Dialogue option and chose the orientation from there. I do not know why this happens. I previously didn’t have the issue, and it was only introduced after this recent update.
I have read some of the troubleshooting options but some of them were basic stuff that I had tried already. The other stuff mentioned in the posts didn’t seem to help either except for the printing through system dialogue which I found out through my own attempts.
Hey @K.Khan, :wave:
Thanks for reporting the printer orientation issue in ONLYOFFICE Desktop! It’s tricky to pin down the exact scenario from the description alone. Could you please record a short video showing the problem?
You can upload it to ONLYOFFICE DocSpace or kDrive and share the link.
This will really help us reproduce and tackle the bug. Appreciate your help!
Admins can feel free to delete this topic.
