hello everyone
i had this issue
when i open pdf (normally i using adobe acrobat DC)
then when i want to search something, just press CTRL+F then they will do the ocr for me, and convert the file to editable and search-able document.
i hear that onlyoffice had it too. but when i try to test with literal same document
they seems not working
can you check them? or they not yet ready?
(no, not with ai, but literal OCR locally)
