DocSpace version:
Type of installation of the DocSpace (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS: Linux
Browser version:
Additional information: Past as plain text is missing in OnlyOffice.
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
Hello @sampersis
To insert a text as plain, you can either use the Paste Special feature with Keep text only option (for instance, for document editor this feature is described here) or simply press CTRL + SHIFT + V.
When I use right mouse click. I do not see this feature. I have searched in the menus and I cannot find it here.
I clicked on the link but I got the following error message:
504 Gateway Timeout ERROR
The request could not be satisfied.
We can’t connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner.
If you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation.
Generated by cloudfront (CloudFront) HTTP3 Server Request ID: g_ZSnD6o-0SOFgMo9KX5oMaDdwny_BZOFCFbLPbBi_nXekhWflgs6A==
Kind regards,
Sam
Paste Special appears at the end of inserted passage like on the screenshot below:
If you don’t see it, then using CTRL + SHIFT + V would be easier.
Thank you. I saw the ctrl option. I suggest that this to be included in the pop-up menu. It can go unnoticable. Anyway, both options works fine.
Thank you for the reply. I’m glad it works.
Since this topic is related to quite another case, you can create new topic in Suggestions category for that.
I am closing this topic as solved.
