Open File Location opens Visual Studio Code on Fedora 43
I’m trying to find the location of an opened document so I:
  1. open the document
  2. select File/Info
  3. click Open File Location
What I expected is the filemanager to open and show the folder where the document is stored. Instead it opens Visual Studio Code
Hello @theking2
Clicking on that item should open a link of file:// type. Can you check if VS Code is associated with this link type?
