Hi,
I’m still having the issue,
here my setup.
ds.conf:
include /etc/nginx/includes/http-common.conf;
server {
listen 0.0.0.0:80;
listen [::]:80 default_server;
server_tokens off;
set $secure_link_secret mfoIJgigeLVMqxuMjGY6;
location /doc/ {
proxy_pass http://localhost:8080;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection “upgrade”;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
location ~ ^/[0-9.-a-z]+/doc/ {
location ~ \.map$ {
access_log off;
log_not_found off;
return 204;
DockerFile:
FROM onlyoffice/documentserver:latest
ENV NODE_ENV=production
USE_SERVICE_WORKERS=true
JWT_ENABLED=true
X_FORWARDED_PROTO=http
NGINX_WORKER_PROCESSES=1
NGINX_WORKER_CONNECTIONS=1024
ALLOW_ORIGIN=*
COPY ds.conf /etc/onlyoffice/documentserver/nginx/ds.conf
EXPOSE 80
CMD [“/app/ds/run-document-server.sh”]
frontend logs:
WebSocket connection to ‘ws://127.0.0.1/9.0.4-4fb0c3cf8025be123e798f71ea733ca2/doc/_Assess%20impact%20of%20Pillar%20Two%20Model%20Rules.xlsm-1758786265/c/?shardkey=_Assess%20impact%20of%20Pillar%20Two%20Model%20Rules.xlsm-1758786265&EIO=4&transport=websocket’ failed: Error during WebSocket handshake: Unexpected response code: 400
Server logs:
apps/vendor/socketio/socket.io.min.js.map HTTP/1.1", host: “127.0.0.1”
2025/09/25 07:44:26 [error] 9615#9615: *137 open() “/var/www/onlyoffice/documentserver/web-apps/vendor/socketio/socket.io.min.js.map” failed (2: No such file or directory), client: 172.17.0.1, server: , request: “GET /9.0.4-4fb0c3cf8025be123e798f71ea733ca2/web-apps/vendor/socketio/socket.io.min.js.map HTTP/1.1”, host: “127.0.0.1”
