I don’t find the way to insert copied columns in the middle of a table because OnlyOffice doesn’t move the original columns to the right in order to create space to the new columns. Most of Office Softwares have this option and, honestly, I cannot work without this feature. Is this option hidden or is there any way to do this? Thanks!
Hello @DavidNAS83
As I can see, you have an answer already:
Unfortunately, currently you can only replace data. As a workaround, you can insert new columns via context menu > Insert column to the left, then move other columns to new position.
Closing this topic as duplicate.
