Imported from UserVoice
Author: Eddie
add more countries to global regions including currency. for example using ₪ to represent money based numbers instead of showing ILS for israel. also, have the OS region as default
Author: Eddie
In the original platform a few important comments were posted, so it seems that the idea is not only to add new region, but to add the ability to customize regional settings.
We’re discussing this idea internally.
Please use the Regional Settings specified in Windows settings for Currency and Date formats. This will ensure that we don’t have to manually customize these–particularly Currency symbol, separators etc.
For instance, my Windows is set to English (India) and uses the ₹ symbol and the currency separators in most other applications are in hundreds of thousands (lakhs) rather than millions. By getting these settings from Windows, you don’t have to add exceptions for every country/language. The information is already there.
Hello @prashantr
I have moved your topic to this existing one, since I believe these ideas share the same main point - making regional settings customizable.
We’re discussing it internally.
We have added the suggestion to internal tracksystem (65020), we have started working on it.
Can we have a option to use international ISO date format for display:
YYY-MM-DD
…and
YYYY-MM-DD\Thh:mm:ss
Because the US-UK date format creates a lot of compatibility issues especially when directly pasted or when sharing to a MS office. This format removes all confusion when being parsed since you cannot mistake 1/2/2026 with 2/1/2026.
Hi @Mudeer,
Just to make sure I understood correctly — you’d like ISO format (YYYY-MM-DD and YYYY-MM-DD hh:mm:ss) available as a global display option in the spreadsheet, independent of the regional settings, correct?
Yes, exactly that.
I couldn’t find any English locale with this datetime format so I’m using SA locale
Hi @Mudeer, I’ve moved your topic here since it’s the same request — locale-independent date format is tracked under this thread (internal reference — 65020).
