Hello OnlyOffice Team,
I wanted to thank you for your effort in creating this amazing software. I recently switched to OnlyOffice Spreadsheets and I’m facing some difficulties that I thought it might be worth sharing with you guys.
Although the spreadsheet software works great in itself, it still misses very important functionalities for Pivot tables for Interactive Dashboard Design:
Pivot Charts, Slicers, Timeline Filters, Report Connections, Dynamic Updates.
Without any of these, it’s nearly impossible to create interactive dashboards, which BTW are pretty important for anyone working with data.
Also in data analysis, dashboards are the final products for stakeholders. That means that data analysts can’t deliver final products when using OnlyOffice Spreadsheets ![]()
I hope you consider adding them in future releases
Ward regards,
Sergio
