RedOS (Linux x86_64) is installed, ONLYOFFICE Desktop Editors is installed, Community Version 9.1.0.173 (rpm).
In a tabular editor, if you “Print the title” (repeat the lines from above) on each page and scale to the width of one page when printing, then a space appears on the second and subsequent pages between the title and the first line.
The wider the table is compressed into one page, the wider the gap.
If the entire table fits the “Real size” in width on one sheet, then this problem does not arise.
It does not depend on which line to choose as the “Header”.
It does not depend on the computer, it was tried on different computers.
It does not depend on the document.
