Ask a “how to question”.
(I hope I can write in French.
Je cherche à créer un lien d’une cellule classeur pour aller sur un point précis de Doc.
Par exemple, à la page 14 du doc, je place le jour et l’heure, que je transforme en lien, lien que je place sur la cellule L54 d’un classeur. Ainsi en cliquant sur ce lien, je retrouve l’emplacement exact sur le doc.
Merci.
Hello @Jean-Pierre
Do I understand it right that both files are available locally on the same PC? So are you trying to link to the local .docx file? Just to make sure that we’re on the same page, please record a video file with the usage scenario, we will check it out.
P.S. Please bear in mind that official languages of this forum are English and Chinese.
Basically, in excel there is function like that. Right click, create a link to the cell and then send that link by email to anyone else. The other person can then click on the link and reach directly the cell of teh file which is located on a drive.
Thanks for your replies and to have added this idea to the internal track system.
I work with documents that are several dozen pages long, and I often need to find a specific point within the document. Currently, I create a table of contents using the date and time as a reference, but this isn’t ideal. I’d like to create a separate workbook containing the references I need.
For example, regarding “banking consequences,” I create a link in “documents,” which I then save in a window in a spreadsheet, allowing me to go directly to the relevant chapter.
I believe there are two slightly different scenarios here.
@Jean-Pierre’s request is theoretically possible on the same PC or within the same local network. We are working to implement such scenario already.
@emat’s request, however, seems to imply shared access to a file stored in specific DMS (some server such as Nextcloud, Seafile, etc.). Dear @emat, please confirm if my understanding is correct.
If so, I believe this kind of access should be handled on the integrator side rather than within Docs itself. In any case, we will need additional details about the scenario.
Dear @emat
Thank you for the clarification. The ONLYOFFICE integration was implemented by Kdrive themselves, so it’s better to contact their support team directly and submit your request there.
